removing GT handles
anyone got a step by step guide?
cheers
Edited by xcore
  • Views 1.6k
doorhandles are easy...
open the door
on the outside of the handle,prise out the long thin handle cover (some are plastic,some are metal)
remove the screw at the front edge of the handle
on the inside of the door,there is a big philips head screw that fits into the side of the doorhandle,unscrew this.
push the handle towards the front of the car to unhook the front of the handle
pull out the rear part to fully remove it from the car
job done!
will the thin metal bit just pop back in or will i need a new one?
will pop back in aslong as you're carefull taking it out
hmm ok cool cheers!
it probably sounds muchharder than it is tbh!
seems simple enoigh i just dont want to damage the metal strip!
cheers
cheers
need to this on mine soon but been putting it off as i thought i would have to remove the doorcard
