poor fuel economy on my 1.2 12valve polo 9n
hi,
does anyone else own a 9n 1.2 12valve polo, if so what are the average fuel consumption figures you are getting, mine is returning at best, 40mpg, which i feel is abismal for a 3cyl engine, i would expect over 50mpg average
any ideas on what might be causing it to be so thirsty, it drives smoothly and runs great, just drinks more petrol than me previous car ( a rev happy 1.25 fiesta which averaged over 45mpg, and it was always reving to the moon)
  • Replies 9
  • Views 5.1k
when was it last serviced???
its on the long life service, according to the service history that would be around 30,000 miles, its not just passing 40,000 miles (it had a new air filter at last service, according to history)
i wrecon maybe an oil change and maybe plugs might help... not certain tho but its about £30 to try...
thanks, i just popped the air filter out to have a look, and it is pretty clean and certainly not clogged, so i doubt changing tha would make any odds
i dont know about it needing plugs, as it fires very easily when i start it, surely if they were causing problems it would be a nightmare to start
i have to wait for the dash display to tell me when its due oil, as it uses VERY expensive Castrol Edge oil
Why are you expecting over 50mpg???
40mpg is pretty good for a 1.2 petrol.
I'm expecting more, because any other 1.2 engine gets the high 40's
this being only a 3 cylinder engine, should achieve more than an equivelant 4 cylinder engine
if i had known it would be so poor on fuel , i would have went for the corsa 3 cylinder, i know from experience it averager well over 50mpg
or the toyota aygo achieves over 65mpg!
i guess no one here owns a 1.2 polo
thanks anyway
you should be aiming for 48-50 mpg..
You can get high 50s but with that little engine it means lowish revs which equals slow...............
Try a new coolant temp sensor, throttle body clean+basic settings and get your lambda probes checked out.
Don't forget the 9n Polo weighs the same as a small bus...
Official figures quote around 47mpg for the 65hp version. Depends heavily on what sort of driving you do I guess. I've never been able to exceed the official figures of a modern car, I did manage to equal them once though on my skoda (57mpg) You have to drive using the instant economy readout on the trip computer and try and keep the throttle in the same place for all driving conditions. Not much fun anyway.
Are these engines designed to run on 95 or 98 RON fuel? That could make a difference.
