polos not well :(
what i time for the polo to play up , 6 days before UD :-@:-@
seems like the clutch is playin up - hopefully it is just that .... it wont go into gear proply its really stiff when changing and sliped out of 5th last night 3 times .
also makes a really horrible sqweekin noise wen its running and when you put the clutch down it goes ??? :-S
anyone know what this can be by the sounds of things ? i hope its the clutch then i can get it sorted by saturday hopefully
cheers
  • Views 1.2k
unlucky mate :cry:
ello mate by the sounds of that it will be you are thrust bearing!
ahhh thats unlucky :sad: , lets hope you can get it fixed in time
could be either 2 things danny, pedal box or gear box mate, exactly same symptoms when my pedal box and gearbox went kaput mine lasted a good 6 months before the pedal box completly snapped and about a year for box to completly blow, sounded like a jumbo jet :lol:
Mine has started with those symptoms this morning!
Could be the rubber bung on the clutch cable mate, mine done exactly the same thing as yours and it was just the rubber bung thats in the top of the clutch that the cabel goes through, might be worn away which makes it hard to change gear etc...
just re read it, its deffo not your clutch ;) or nothing to do with your clutch
