Past hour
Hi, are you still looking for a gearbox? I will be able to offer either the gearbox that is currently on my MH engine or the one I’ve taken off my AAU- both four speed. Both low miles 50/60K, although I haven’t used either yet. I’m in biddenden, Kent. I suppose it’s light enough to post, actually- but obviously at some expense. Text me if interested 07549 667632. Today
1996 VW Polo 1.4SE
I wonder if the base mount of the carb has developed a fine vacuum leak. It should be firm against the rubber, but insulated against vibrations. The rubber hardens over time. Can you wobble the carb left right or back and forth? Will the engine fire with some Easy Start spray (diethyl ether) or a small amount of fuel dribbled down the carb throat? -
Thanks for the response, and no it is intermittent in all sorts of conditions so I believe it isn't due to engine temp as far as I'm aware, usually works until after 8hr work shift. Usually after a drive or two it might manage but afterwards it wont work when I come to try again after a few days. I've had the garage take a look and helped me assumably fully disconnect the rest of the immobilizer as it was faulty in the past anyways, assuming that has now been fully removed from the equation it is just air or fuel starvation. In this case I do have an electric choke I was also curious how it might mix in with this problem. As I already said, it wont start even after days but randomly it will and it seems fine when it gets going, usually drives somewhat well besides idling too long and sometimes when setting off depending on how long I let it warm up, I tend to give it between 2-4 mins. Most recently it started and died after idling for a few mins and hasn't started for two days, I've tried both pumping gas pedal and pull pedal down tricks and doesn't seem to work, my next try would be to check if it smells of fuel or not in carb and check flap. I appreciate the help.
