  2. 1vw2many
  3. Today
  4. nige8021
  5. 1vw2many
    Had a search but no joy 😊. I'm after a new Mk2f breadvan boot lid gas strut. Please and thank you.
  6. Yesterday
  7. Rupert
    The EA211 1.2 TSI is belt driven, so there's no chain tensioner to blame here. With no fault codes, I'd log the per-cylinder misfire counters in VCDS while it hesitates cold. They can register misfires below the code threshold and point at which cylinder to chase.
  8. Last week
  9. Aaron0796
    Aaron0796 replied to Connor13a4's topic in Mk2 Polo
    Been a while…but how easy was the splitter to fit?
  10. Yeti
    Total stab in the dark, but I know the old N/A 1.2's had an oil pressure actuated timing chain tensioner. Not sure if these ones do. Might be taking a bit longer to pump itself up when the oil's cold.
  11. Jukka
  12. Rupert
  13. Rupert
  14. Rupert
  15. Rupert
  18. Earlier
  19. Charlie Cawte
  21. Yeti
  22. Mludford
  23. Rupert
  24. dvderlm
  25. dvderlm
  27. dvderlm
  28. dvderlm
  29. dvderlm
  30. dvderlm
