Past hour
Hi All We can confirm our seasonal opening hours will be as follows: Up until the 18thDecember: Normal hours. Saturday 19th December: Closed Sunday 20th December: Closed Monday 21st December: 9.00am – 3.00pm Tuesday 22need December: 9.00am – 3.00pm Wednesday 23rd December: 9.00am – 3.00pm Christmas Eve: 9.00am – 3.00pm Christmas Day: Closed Boxing Day: Closed Sunday 27th December: Closed Monday 28th December: Closed Tuesday 29th December: 9.00am – 3.00pm Wednesday 30th December: 9.00am – 3.00pm New Years Eve: 9.00am – 3.00pm New Years Day: Closed Saturday 2rd January: Normal Hours Resume. Regards, Dan. Earlier
