  2. Jukka
    Has anyone found a solution? This morning it was -8 here and the issue was back on with its full glory.. As with the OP, the issue disappears when oil temp reaches 70c
  3. Yesterday
  4. Rupert
  5. Rupert
  6. Last week
  7. Rupert
  8. Rupert
  9. dvderlm
  10. dvderlm
  11. Charlie Cawte
  12. dvderlm
  13. Yeti
  14. Mludford
  15. Rupert
  17. Earlier
  18. dvderlm
  19. dvderlm
  23. dvderlm
  24. NickJ
  25. Breadvan Princess
  26. ajoubertbb
  27. xlimage
  28. xlimage
  29. Pistachio
