Bracket came fully away from the floor on 1 bungee cord after 5 miles. Used 2 bungee cords with one around rear bumper mount, and a ratchet strap around the box, up through the floor and anchored it at the strong rear seat belt mount point. That held over some of the bumpy roads in Fenland. (not North Brink where a young Polo driver died this year - though he was doing 90) Beginning to wonder if the rear shocks or springs are done for too. Same miles ish as the fronts. Tried a bounce test and could not really make the chassis move down! Stood on the open boot sill, jumped off. It hardly moved. Though I could lift it a bit by hand at the rearwing. It should be lowered 40mm at the back, 60 at the front, but looks kind of level not raked. I can investigate when I weld the boot floor. Last week
