Wheel Bearing
Does anyone know if the front wheel bearings on a 98 1.4cl are pressed into the hub or not. would really appreciate any help or info because i really need to get this sorted.
  • Views 751
Hi hughesy,
Yes - cos I'm in the middle of trying to get mine back on the road after fitting new bearings.
http://www.clubpolo.co.uk/forum/index.php?showtopic=100784
The old bearing races are pressed out, and new ones are pressed in.
Then, if you're refitting the original hubs, there should be a good interference fit on the inner race.
Mine were worn out, and one actually rattled in the new bearing, so I ordered new hubs, which don't fit, etc. (see above)
Here's that other link from a French site about how to DIY your own bearing change :
http://www.pololand.free.fr/forum/viewtopic.php?t=1031
and the thread that came from :
http://www.clubpolo.co.uk/forum/index.php?showtopic=99024
Edited by seamonsta
cheers, might try an do it this weekend if i can be bothered, but if its gonna be a pain to do i might just put it in the garage!
