Tintting cluster and headlamp lens?
Hey guys.
Want to stand out a little more from the rest of the mk3 tornado reds out there and want to tint my lights, front and back.
Fronts
I want that smoked/tintted look but don't really want to report to lens removal to paint the nonreflective part. Can i use tint spray on the lens or is this illegal? I only want a light tint nothing major! Same with indi's.
Rears
I've got late spec clusters. Should i get early spec and tint indi's red, or darken up the entire late specs with nontintted strips on the indi part?
Anyone done anything similar?
Mike
  • Views 1.5k
i think it's illegal to spray over you are headlamps...
i used rolo's tinting guide for headlamps and it was really easy...
cheers dude
how long did it take you do get it done?
Also don't suppose you know if its illegal to tint the indi+repeaters red???
you've already asked about the rears before
http://www.clubpolo.co.uk/forum/index.php?showtopic=102513
yes i did sir, but this is a different question!
just asking for opinions on if i should darken late specs, or red up early specs!
think i might just darken the indi on late spec
Mike all in all it took me about 2 hours... last time i fucked around with my headlamps i ended up getting them all out of allignment and busted the plastic surround where the lights screw into so that was a pigs ear!
luckily i had a donor car to make mine from, 4 screws and the headlamp is out of the car (with it's mounting bracket) unscrew the 2 adjuster screws and pull the lamp away from the ball joint that locks it in place, then u can put them in the oven :)
just a process of taking the glass away from the lamp waiting for it to cool down, mask, sand, spray, wait then glue back together once u have cleaned the lense :)
oh, red up early specs... firstly they're cheaper, secondly like jon points out, if u sand the orange back quite a bit then u need less tint spray as they go red quicker AND they still shine orange...
