fitting remote central locking on polo 9n
I've just bought a cheap alarm kit from ebay which has remote start which I've just found out here is no use in my 04 9n. It also has microwave and shock sensors which to be honest I'll prob not fit. So the only thing I'm using the alarm for is remote central locking. I'm hoping someone on here knows the ins and outs with wiring it up and can tell me where's the best place to splice in and what colour wires I'm looking for.
thanks in advance.
  • Replies 13
  • Views 12.9k
you are going to need diodes and a 1k resistor to get it to work
you need 3 diodes for the door trigger circuit and that is quite fiddly to do
also the locking is negative resistive locking
so you will need to connect your lock wire from the alarm to the blue/white in the drivers footwell then you need to put the 1k resistor in line on the unlock wire and then connect this to the same blue/white wire that you connected the lock wire to
Cheers for getting back to me. I was thinking I was only going to need to lacate door lock/unlock wires, splice in corresponding wires from alarm and job done! If I'm needin to bring diodes and resistors into the mix I might give the whole thing a miss. How much would a decent auto electrician take to fit it for me? Mind you if I was one and someone came to me with a 20 quid alarm from ebay I prob wouldn't want to touch it.
where are you based
as i own a mobile alarm and audio fitting business and depending on location i could fit it for central locking only
where are you based
I'm up in Glasgow, see from your profile your hardly round the corner. Cheers anyway. I'll look up someone local tomorrow
Hi troublestarter. I am in australia and taking delivery of a polo 2007 with central locking but want to fit a remote like shaun.
So is this how it works: connect a 1k resistor in series with a diode ( anode to lock side) to earth triggers OPEN and similiary for close?
If this is the case why do i need 3 diodes? also can you tell me what colour is CLOSE, OPEN and GROUND?
is here an instruction or schematic you might have?
Cheers and thanks :-) -
I've been considering the same thing for my car too.
I could prob come up with a simple circuit using some diodes and a 1k resistor - something like a 1N5820. Is a 3A rating enough?
Can anyone (troublestarter?) give the wire colour codes for the central lock motors? Maybe even an idea of component spec?
here goes
wire up your alarm/central locking kit for negative locking as per the appropriate fitting instructions
the lock wire on the car is a blue/white in the drivers footwell
connect your lock wire directly to this
then get your 1k resistor and put it in line on the unlock wire then take the end of the unlock wire and connect it to the same blue/white wire you connected the lock wire to
thats the central locking done
as for the door trigger circuit i will try and find the diagram for connecting it as it needs cuttind and 3 diodes putting in
the diodes are needed for the door pins not the locking
  • 4 months later...
here goes
Hey!
Iam about to install a DEFA 800 CAN-BUS alarm in my polo 2006 (9n3 i guess, dont have a clue what that nr stands for).
According to this post I need that circuit for the door pins.
I guess I also need to tap in to left and right turning lights as well, any chance you got the color of those wires in your head ?
Best regards kman2002
indicators are black/green and black/white at the steering column
if you are fitting a canbus alarm are you sure it has seperate wires for the indicators
It seems so..
Do you mind explaining the diod stuff for me?
And how to solve it?
//Kman
  • 12 years later...
Can you please help me with this? I found everything but this... 🙄
