Argh , What Can I Fill This Hole In My Dash With ?
cut a long story short i am a idiot for putting a switch there in the first place
any ideas on what i can either fill it with or someothing i can put over it to hide it ??
  • Replies 29
  • Views 3.1k
woah what they use a spoon? :S,
could cut a bit of square aluminium and cover the whole section, or find something to fit thats slightly bigger and file the hole out and fit it in neatly
other then that i have no idea mate
i put the hole in , as car was going for MOT and dident have a working horn so my dad got a switch for me (prob the biggest push switch you could get :-( ) and i had like 10 mins to fit so did a badge job getting my horn working again :? feel like such a prat for putting it where i did ,
i could just change the whole dash :? that would get rid of it lol
Voltmeter?
It becomes a conversation piece:
"hey whats that hole for"
"thats where my boost guage is going ;)"
Edited by Sp00n
sorry dude miss read the first post thought someone else had done it,
you could always bung a shift light in it?
Stick a vw logo in it ?
Can't you just replace that bit of dash?
indeed it does but looks gash , dought i would fit a guage in there
we all mis read things lol , i do it quite a lot!
how much is a shift light and what does it really do ?
that is basicaly the whole dash cant just change a part :-(
Shift lights aren't much, they work off the rev counter as far as I'm aware and they flash a colour at the rpm you set it to. So you would work out your optimum RPM for all gears and change when it flashes. Think need for speed or fast and furious stylee.
Edited by DubDanny
push button start easy ish to do look mint , maby black button spray thr vw symbol on
i think the switch i put in there was a either a horn switch or engine start , just didnet file it out or anything lol....... might have a look see how easy push button start is , and put that switch back in ii can find it again and fit it proper :thumbsup:
Push button starts are piss to wire up il make a little guide in the electrical section how to.
cheers , post the link when u have so i can see what to do
Well, that all depends on how much you love your car :p
Durex lube is pretty cheap and widely available! :lol:
seriously, start button sounds cool :thumbsup:
Take dash out, retrim in "carbon fibre" covering hole in the process!
Sorted lol
I would agree with start button, or get down the scrappy, find any random voltmeter type dial and stick that in, doesnt really matter if it isnt actually wired up or working!
what about an idicator blank from an early mk2 golf? or some kind of cool badge?
what about a a big thick bit of electrical tape in black = cheep and cheerful
or
walk round B&Q and look for abig rubber or plastic effect blanking plate with the screw on the back then put a bit penny washer in behind and tighten it up so it covers it.
or
wolfsburg logo
or
a guage would be easiest but might look pants as most gauges are 56mm iirc.
or
got to the scrappy with £20 and buy another one and spend a sat or sunday changing it.
Edited by genesisGT
i like the sound of the push start and the volt meter and the rev light thing.... i almost wish i had a gaping hole in my dash
push start ftw purely becasue i would like to see what it looks like and its more interesting than key start
i am thinking about doing this , has anyone else wired a push start on a mk3. as i read the intrtuctions someone else posted on doing a push button start but that was for mk4 would it differ much ?
dont make me answer what you should fill that hole with buddy.
lets just say, dub love, taken too far. :lol:
http://www.clubpolo.co.uk/forum/index.php?showtopic=140106
Heres the guide i made it will be the same for the mk3 and any other model car all cars have a ignition wire and a starter wire its such a cheap easy mod to do and you can still start it with the keys if you like and you need the keys in so you know its safe.
This might sound to simple but measure the hole looks about 30mm to me. Then fit the type of rubber gromit that is in all car boots ( to drain out ). Should fit the hole nicely.
