my cars a write off
I've just found out the polo's a Cat C write off
what do you need to do to put a Cat C write off back on the road ??
how would this affect a future claim
what would the value of a fixed Cat C be
and is it worth fixing a Cat C car ??
please help
pic's now up on post 29
all it needs to put it back on the road is a Mot and a V.I.C check
Edited by BSJ1
  • Replies 47
  • Views 4.6k
reduces the value quite a bit. cat C means structural damage and requires a VIC test before it can be put back on the road.
Edited by polo6n2g40
CAT C means un-economical write off... not necesarily structural damage. Do you own the car or are you looking to buy? In theory, my clutch going on my polo would make it a CAT C as a clutch fitting from VW would cost £550... more than the car is worth. Argue your point if you own it, go to a garage and get a quote to fix it for less than the price of the car...
this happened to my capri, a van hit it but luckily someone saw it and took the number plate! ripped off the back bumper and put a ruddy great dent in it! Insurance for the van valued it at £750 (fucking mugs!) and repairs to be about £800 :shock: thus renering it a CAT C! i went to my local cappa garage and they quoted it at £350 for the work, and the cars value at £1500! so, i eventualy got a cheque from the other parties insurance and fixed it myself (half hour with a hammer and a lump of wood, spray of apint, good as new! and went bumperless 8-) )
good luck dude!
cat anything means it has been catagorised ie write off aka un economical repair.
cat d is paint and or panel damage, does not require anything to go back on the road.
cat c is structual and so requires vic test after repair.
cat a+b cannot be put back on the road.
Cat C is not necissarily structural damage, you will find a lot of insurers are catagorising older cars as cat C now regardless of damage there usually simply too expensive to repair.
Also a VIC check is nowhere near as drastic as you will think, the DVLA simply check all your chassis numbers etc and compair the car against the original engineers reports to make sure the damage is where it says it is etc before they will issue you a V5. Its just to stop people ringing cars and/or using stolen partrs to repair damaged cars.
I think a VIC check is about £35 but you get your V5 for free, if you car was a Cat D you still have to pay £25 for your log book.
Heres the list from a Salvage company I use quite a lot.
Category A
A vehicle which has been written off and must be totally destroyed.
Category B
A vehicle which has been written off from which spare parts may be salvaged, but the body shell must be crushed and the car should never return to the road.
Category C
A damaged vehicle which the insurer has decided not to repair, but which could be repaired and returned to the road.
Category C vehicles require a VIC inspection. Recorded at DVLA and HPI.
Category D
A minimal damaged vehicle which the insurer has decided not to repair, but which could be repaired and returned to the road.
Category X
A vehicle which is not listed as being damaged on the HPI register, or one which may have very little damage. These vehicles may have been stolen and then recovered.
Vehicles categorised C require a VIC test before the DVLA will issue a new registration document. This will then be noted on the V5C.
A Cat C vehicle will obviously not be worth the same value as a non damaged car, so I guess it all depends how attached to your car you are or not. Also if your buying it back from the insurance company you will get it reasonably cheaply because they simply dont want the hassle of recycling or selling you car on, although most have there own prefered salvage yards anyway.
That technically isnt true, on a VIC they dont check the car at all in regards to repairs or damage this is/has already been done by an insurance engineer.
A VIC (Vehicle Identity Check) is simply the DVLA/VOSA making sure the car is what it appears to be, they check chassis numbers etc and if any repairs have been done they may check serial numbers from the parts used to make sure not from a stolen car.
As explained here.
http://www.direct.gov.uk/en/Motoring/Buyin...icle/DG_4022107
Edited by 89rallye
and you only get one shot at a VIC test too!!!!
89ralleye has it right! :thumbsup: read my post about trying to avoid being CAT C, i managed it!
really, are you claiming off your insurer for a worn clutch..... ummmm nope
cat C is as said an uneconomical repair - nothing more, you can have cat D cars with structural damage - structural meaning it would need jigging etc.
as your vehicle has already had a total loss payment by the insurer it is now worth next to nothing to them.
Edited by bobby_hill
quite obvious as if you fail a identity check - you have failed to prove the cars identity - i.e re shelled with stolen shell etc..
VIC checks are nothing to worry about if your doing nothing wrong
really, are you claiming off your insurer for a work clutch..... ummmm nope
no not i'm claiming my clutch dipshit, i said 'in theory'... :roll: ie if my clutch were to go, i would probably break the car as it would become an in-economical repair!
Edited by richie_stix
look i was only making a point i was trying to be helpfull!
dipshit, you called moi a dipshit.... ha i understand you were making a comparative quote now - was scanning uber sorry..
nicko belt up fuckface - joining the band wagon.,
thanks everyone its my car its been parked on my drive since the accident
how did you manages that ??
and i haven't had a penny for the car and i've still got my log book
and the damages is only dents
will it cost more to insure a Cat C thought ??
how can the car have a loss against it? - unless it was cat C before you broke it
no worries, felt like saying dipshit! :lol:
BSJ1... its the third post down from top?
ok thanks
here a link to the pic's of the car
http://www.clubpolo.co.uk/forum/index.php?showtopic=134563
similar level or damage to you no? get several quotes from garages for repair costs, get valuations of similar cars... and fight fight fight! i guess you are claiming of mr BMW?
yes i was trying to claim off mr bmw
but the insurance companys have already decided its my fault he revered into me
i'm going to call my insurance company again and see whats happaning now
i only found out it was a write off from text check 83600
Edited by BSJ1
As richie_stix says its worth fighting, there are loads of posts over on the Volkszone forums about people with Camper and beetles who are doing this all the time.
Insurance companies dont want to get involved with older cars, I remember one case with a camper the guy got his own quotes from various VW restorers and presented them to his insurance company and did it that way. The insurance company wanted to right it off since they will just ask a standard insurance approved bodyshop and they dont want to get involved with a rusty old camper..
As it turned out the guy won, camper was repaired and as a bonus he had a lot of extra work done that the restorer had just billed into the insurance quote. ( Not that I would condone this in any way ;) )
thanks 89rallye
but as i'm TPFT i'm going to get jack shit for it
so it was your fault you crashed and thats why he beat your dad up. theres no shame in having an accident, the reason everyone detests you is because you've come on here all mr high and mighty it wasnt my fault attitude. (amongst alot of other things.)
no it wasn't my fault the insurance accuser for my insurance company agreed with use about the damaged to my car
if you look at the damages to my car you can see i didn't rear end the bmw
i dont care if you triple backflipped into the bmw, that doesnt proove its not your fault. you could have driven your front wing into the back of him which is the decision your insurance company have come to.
ok so what about the dent in the back ??
