Okay...?
Leon
Edited by LeonL
  • Replies 20
  • Views 2k
can you smell fuel inside the cabin?
No i dont think so?
It is possible to source a new pipe, id try gsf car parts, had something similar on an old golf mate. if it thats badly rusted just replace the whole thing, would probably spend more repairing it.
Okay brilliant, any ideas on what exactly it is that i need to be buying/asking for?
Yes That's the pipe for the main breather tube that you can see through the corrosion. The pipe is extra protection for the tube incase of impact on that that cavity of the car. The tube is sealed in fine but doesn't have any protection so I would get it seen to pretty quick. There might be some sort of quick bodge repair? but I'd personally prefer to know it's safe. Mines pretty crusty but I've treated it with waxoil/bilt hamber cavity wax.
I reckon drop out your fuel tank and get an experienced welder to trim of the rotten area and sleave or butt a fresh piece onto it making sure there are no sharp edges. Or just get the whole part from VW? It's probably the worst area for rust because as you see the fuel tank filler neck gets hit with all the road salt and crud along with that pipe. While off treat and stone chip and/or waxoil/underseal your tank especially on the filler neck. and treat the problem area too.
I've heard that Dinitrol underseal good and checkout http://www.frost.co.uk/ for other rust prevention/inhibiting products.
I've seen folk scrapping a whole car or shell because of this. At least you'll know it's done.
Edited by MacColl
I'll get the whole part...Any ideas on what it is i need to buy though? Just the pipe or would i need a whole fuel tank?
Thanks for the great information as well, greatly appricated
That part has nothing to do with the fuel tank. It is basically the metal tube that houses the main breather tube. I would try GSF then VW who will have diagrams on there system so you can point out what you need. Failing that a welder/fabricator could probably make up something quite easily. A pipe bender would help I'm sure. It still has to be welded in and possible seam sealed.
Check this thread for diagrams:-
http://www.clubpolo.co.uk/forum/index.php?showtopic=146394
In first diagram it is the metal tube that part 6 sleeves into.
Good Luck.
Good Luck.
hmmm i see so i should just go to GSF and ask if they have the metal tube that houses the main breather tube right?
I thought it was the fuel filler pipe since it seems to lead straight to the fuel cap?
Edited by LeonL
No unless I'm completely misinterpreting your first post it is the pipe that protects the main breather pipe that joins the filler neck at the top.
I would maybe get a welder/fabricator to look at it first. Just remember that the fuel tank must be well out of there before any welding in that area.
Erm...its exact location is behind the rear door card on the drivers side of the car, in the inside....
uh oh i think i have this problem :(
Why you think that...?
I was thinking about this earlier, what would peoples thoughts be on not having the metal pipe there? Like using something like a braided hose instead of the plastic one? I know this is not necessarily going to be an area for an m.o.t. fail but It has to be safe at the end of the day and of course rust free. as long as there isn't a sharp edge to shear the pipe in an accident.
On older cars like Triumphs theres bugger all protection on things like breathers from what my mate was telling me.
Because when i changed my rear door cards i found the exact same thing.
Dont worry about it, remove the rust and leave it. Every mk3 has this its just the breather pipe and wont make a difference with no metal pipe around it.
Yeah but little things like this annoy me so i want it sorted :( lol
Will probally take a trip to GSF some time next weekend and i'll let you all know if they could help me out or not!
GSF wont be able to help you as they dont sell items like that, to fix it I think you have to remove the inner rear quarter skin, weld a new pipe in and then weld the skin back on, as I doubt you can get a welder in there.
Blah :( Seems like alot of work...
Try this for a solution (read the thread...)
Rusty fuel breather pipe fix
Pmed with a few questions,
