Dash Rattle, and rear rattle
coming from the clocks, are they sposed to have some kind of foam padding all the way round where front of the clusters meet the dash plastics? only got some at the bottom and if you push the top of the cluster in the rattle stops
so wondering if theres something missing?
also sounds like something in the boot is rattling as well, common things it could be after lowering as i swear it wasnt there last week before i lowered the car?
any help/advice much appreciated
cheers
Coops
  • Views 1.5k
Hmm, I think it might be the boot liner that's rattling, there's a good guide here on how to get that taken care of.
Wow my guide finally came in use, mine started rattling without lowering so it's possibly just a coincidence, to see if it's you boot lid rattling open you are boot and tap the corners it should be solid but if it taps against the boot that's your rattle!
cheers fella, i'll give it a try
can hear the boot lock rattling when thats empty, as well as the little valve built into the fuel filler bit knocking against the cap.
I have a funny dash board squeak too but if i push up against the bit above the radio it stop's :lol: cant source whats causing it.
Edited by Cymro
nope it is none of the above
going to start stripping trim out to see soon
also anyone any thoughts on the dashboard clocks?
cheers
Ben
