Engine Start Button
Was thinking about installing an engine start button, would it be fairly easy to install and any recommendations to which kit to buy?
  • Views 1.5k
It depends,
Most buttons are just a press switch to make contact.
So you'd turn your ignition on with the key as usual, then instead of turning to the crack position on your ignition switch, you'd press and hold the button until the car starts.
You can just run the switch in parallel to the connections on the igntion switch for cranking, then you still have the option of using the key to start the car also.
Cheers,
Most of the kits have detailed instructions so i might just give it a go... :)
If you do, put up some pictures to show us :)
Good luck.
Edited by Mr Blobby
