8v Front fogs
Bacically got some few days ago of ebay but theres no wiring or switch, I contacted the seller when i got them but they scraped the car bout a week ago so thats a bummer.
I can get hold of a switch quite easy, i think.. :lol: but what wiring do i need?
i have no idea and i was gonna fit them later as its not raining but it would be a little bit pointless. :lol::?:-(
Thanks.
  • Views 730
Not only do you need the switch, but you also need a relay and some 14/030 and 28/030 cable, all of which you can get from your local motor factor.
Wire the switch from the fuse and to the relay with the 14/030 cable (for a neater job).
Wire the feed from the fuse to the relay and from the relay to the lights with the 28/030, use this also of course for the earth connections from the lamps.
Regards.
P.S. 14/030= 14 strands, each strand being .030mm, 28/030 =28 strands, each of .030mm.
From a recent thread:
http://www.clubpolo.co.uk/forum/index.php?showtopic=227899
Check the link he has provided...Hopefully that is what you are looking for?
Obviously just need the switch and relay then...
Good luck :)
