Mk2 Bay Harness, Engine Side
If you pull the clocks out, on the multi plug there should be a red/black wire, (I think it was pin 19 on the ECU plug). Its also on the brown plug down by the old mk3 coil.
light loom should be entirely separate. :lol:
The only wires that were left attached to my engine after the carbs were the:
Battery > Starter
Alternator > Battery (I have separate feeds for alternator & starter, not piggy backed via the starter like the original setup)
Alternator D+ > Clocks
Oil Sender > Clocks
Temp > Clocks
And of course the Earths, (Head, Gearbox & Left Engine Mount)
Then I fitted the mk2 ignition loom.
  • Replies 45
  • Views 2.5k
Yeah we'd established that lol.
I just wanna know if I can disconnect this brown plug and lights and everything still work ok.
I just assume it has the ignition feed and such from the loom nearer the wing of fusebox instead of the one inboard
Nick you on about these plugs
Yeah but mines only 2 pin & brown. The one in the bracket there
In reply to Cymro's post:
Its not though is it, that brown plug, the other half is in the lighting loom. The part thats in the lighting loom, is that the part that goes back to the clocks?
Bit that i have went from brown plug to ECU. Thats the only red/black i can find.
I swear half of this loom is missing.
Yes Mark, but yeh.. mines 2 pin brown like Yarris
Edited by B-shaw
Revs and ignition??? Strategically placed next to coil? Haha
That picture has confused me more :lol: :lol:
Picture nick sent me, plug into coil is brown, green, black
Your above is brown, red, black
The one thats going to nicks coil is what you have instead of the brown plug.
Beat me to it yarris by posting the pic I'm describing :lol:
Edited by B-shaw
You're makin this hard work toby
Its what i do best :lol:
I think i have it sussed as soon as i can find the other part to this brown plug. cus atm it will just be floating about in the bay and my entire ignition/fuel system will have no ignition feed and I'll have no rev counter :lol:
Thats providing it is doing as i assume? And thats main feed from ignition & revs to clocks?
I'm just gonna bell it out, it's defined an physical then rather than people saying "it's easy" and not even being able to give an answer lol
:lol:
Wish i just had a MK2 to start with. Be none of this awkwardness.
I'll do a detailed write up for this when I'm done. One that can be understood by douchebags like me that don't understand wiring for shit :lol: :lol:
lol you go girl ;)
This is the brown plug i was looking for, which isnt brown.....
Has ignition and revs going to clocks. And a random brown wire that i think i just earthed before.
So, the lesson to be learnt, is that A, its in the lighting loom so it is relevant (as Cymro said it wasnt lol) & B, that it differs from SPI loom to GT loom.
I'll just hard wire it to that, fuck the plug off as it don't match anyway. Luckily, its already been taken out of the wrapped loom as is dangling about in the scuttle. So that saves me another job lol.
Should result in a wire free bay, besides starter/alternator/temp sensor/oil sensors/dizzy.
Just now I'm missing my revers sensor & washer motor sensor :lol:
might go wire fuel pump, AFR gauge, ignition system, limiter etc!
me want limiter :crybaby:
Nicholas, is the reverse sensor plug in the lighting loom or the engine loom? What colour is the plug and the wires?
lighting loom man, dunno I'm indoors. ill tell you in a bit lol.
I know, i looked. It didn't help me.
my lighting loom had nothing to do with anything else. :lol:
ill disconnect the brown plug as I still have that in my bay and see what happens when I unplug it.
The plug on mine is black for the reversing switch.
Isnt that 3 pin plug in your picture the one for the square coil?
I dunno, i have the coil plug on my bay loom?
