Driver's electric window is sluggish
Hi
I have a 1998 Mk3 (MN6) Polo 1.4CL.
The driver's electric window descends fine but rises very sluggishly.
How can I fix this please?
Best regards
David
  • Views 923
Lube the glass runner channels with some vaseline or similar!!
Please will you suggest how to do this? Access seems difficult. I have partially removed the inner, soft, door covering. So I can access the mechanism with difficulty.
David
David
It will most likely be down to a lazy door regulator,and you will need to swap it out,look on the bay.
Edited by mickypolo
David
Get a can of silicon spray and spray it in the channels of the window rubber then work window up and down
David
Thanks for your reply. Having sprayed silicon around with little improvement, I guess you are correct.
How easy is it to replace the regulator? Must I remove the window?
David
