New owner - 6n2 advice
Hi all,
Passed my driving test last week, and the next day found a polo to have as a first car.
It's a W-reg 1.4S 16v, really clean inside and out, but with some minor niggles (passenger window dead, driver's door locks but not unlocks).
But I can't complain since I was on a budget, and needed the car ASAP to help get to work.
Other common issues I have read about are gearbox and pedal box, both of which seem fine for the moment!
Mileage is pretty high in 120k, but for a VW engine that's just breaking it in right? :smile:
5 years ago the mileage was around 57k so it's done a lot of mileage very recently, so not reading too much into the actual figure (though it does mean the cambelt is due soon!)
Any other advice or general things I should be looking out for?
(I may sound negative but I'm loving it, just would rather the car be perfect that's all!)
Not looking to modify it any time soon as the insurance is already double what I paid for the car.
Also how do I check what power output this has? Can it be a 1.4 16v and still either be 60 or 75 hp?
post-146552-0-59228200-1382720325_thumb.
  • Views 571
The 1.4 8v had 60hp the 1.4 16v SE had 75hp and then the rarer 1.4 16v (literally just labelled 16v) had 100hp. (http://www.clubpolo.co.uk/forum/index.php?showtopic=277371)
Have a look for the engine code, either on the block or in the boot (easier to find) under the carpet, there should be a sticker, the code will be 3 letters. Also the writing can be a little off to the description.
It looks like a 1.4 8v to me as i think the 16v's have the grill emblem.
Whip the door card off and have a gander, sounds like the mechanism is stuck or something. There are a few guides on how to do this.
Electric window is probably the switch as they get water damaged. When you take the door card off, switch the connectors for the window switches around and see if it works, then you'll know if its the switch.
Other than that, check everything works and have a good look underneath.
Yours is an s spec model as it has electric windows se models all had fog lights, different interior and alloys etc. all 16vs are 75bhp except the very rare 100 Bhp or gti model which is 125 Bhp both of these would have had grille badges one with gti one with 16v.
Check when timing belt was last done.
These are good solid cars.
