three problems - one long journey
1) locking fuel cap key broke off in lock in petrol station. Fortunately I could get the cap off and back on.
2) Sony radio cassette fascia plate (I had removed it while parked overnight somewhere dodgy) will now not stay in place over the smallest bump.
- much as I like my engine note I don't like it for 3 hours none stop.
Suspect the car wanted to stop me and 500+ other motorists getting bored:
3) accelerating hard out of the 50 roadworks zone and wondering when the Porsche Boxster in front of me's aerofin would lift, suddenly the LED in the temperature gauge started flashing and needle began to rise.
Having an air-cooled engine conversion occur in the outside lane of a motorway is not fun. One idiot undertook in the middle lane. Fortunately I was able to indicate, manoeuvre to inside lanes and then finally engine off, flashers on coast on hard shoulder for a very long way to cool it down. Stopped just short of a police only picnic spot. Bottom radiator hose damp. I had replaced it when I had a top hose leak earlier this year so it's not the hose and not the clamp. When I took my head out from the bonnet the other side of the M4 was nearly at stand still. Wow look at that a car with flashers on and a bonnet open! Refilled expansion tank with about half of 1.5 litre bottle of water. Restarted. Drove 10 meters then let it idle. No detectable leak. Drove on. Stopped at service station and refilled the bottle in their wash-room. Refused to pay £9.70 for 1 litre of antifreeze. Likelihood is it will leak out again. Which the coolant did 3 more times over the next 90 miles - each time after accelerating hard. At second time used a third of a bottle of radweld (it treats 10 litres I think), but it still recurred. Finished the whole bottle of radweld (all the shredded beetroot from the bottom of the bottle) took me the last 50 miles gently no problems.
  • Views 783
so wheres it leaking from?
I've no idea yet. And it's raining so I can't see.
I've got some UV dye from investigating an aircon fault (not my car). Can I use that in coolant?
Edited by dvderlm
I suppose PV=RT so it needs big heat of hard acceleration to increase the temp and then pressure.
It's got a self tightening clamp. None of the other self tighteneing clamps or jubilee clips have leakage signs.
After using the radweld the temp needle sat unmoving just to right of the LED - which is how I used to remember it, while it had recently been below the LED and would wander a bit. I did have some coolant loss each month. I wonder now whether it's had a small leak for a long time. If it's spraying steam at 100degrees + that'll cool rapidly. No telltale white antifreeze though?
Cleaned some reddy-brownish muck (fine rust?) and smeared heavy duty silicone around the end of the pipe where it meets the rubber bottom hose for now.
No leak so far - might have gone down slightly - but not dared drive hard. If the self-tightening clamp was on a swage bulge, rather than between two swage bulges could that allow leak when at high temp and pressure?
Found a cheaper water pipe by looking for
030121065C
Not the metal water pipe after all. No, it was the rubber pipe from thermostat housing to heater - which had developed a minute split near a jubilee clip.
... and I've mended the radio fascia with some no more nails double sided tape.
But the fuel cap is proving hard to source.
I now have a locking gates made VW polo cap, that looks beautiful... but it is a euro valve vented 34mm two lug bayonet.
Won't fit physically and wrong venting system.
Think it says 861201551 on the old cap.
