mk2 side bumpers
Hi all,
is the side bumpers on the doors screwed on or just adhesive?
I would like to remove them!
Matt
  • Views 1.6k
As long as it's the plastic ones low down, then yes, they are just stuck on. If it's the chrome ones at door handle height (normally only found on the GL, which is a rare one), they are drilled and screwed.
If it is the plastic ones, see here for a how-to guide - https://www.clubpolo.co.uk/topic/109552-removing-bump-strips-on-mk234/
Bear in mind the adhesive is very, very strong, so if you don't do it right, there is a risk of taking paint off.
Cheers dude!
