Mk2f polo coupe rear brake conversion
Hi, I am doing a rear brake conversion on my Mk2f coupe gt conversion  got mk2 golf stub axels Calipers carriers discs and pads, was informed just to use Mk2f handbrake cables wondering how I would connect cable to Calipers, also got a brake bias valve but unsure where to mount, any help would be much appreciated
cheers, Ross
You need handbrake cable adapters, there machined tubes that slot onto the caliper allowing the standard cables to be used.
If it's the proper bias valve then it goes on the rear axle.
Thanks Nige, was just about to go searching for that. 😂
