GT & G40 specific items
Please correct these lists as appropriate, just trying to collate all of the above information into one post, I'll edit as appropriate:
Polo GT Specific Parts:
Engine & Assoc. Systems:
Engine: Multi-point fuel injection with higher compression ratio.
ECU: GT Specific
Inlet Manifold: GT Specific, large bore.
Gear Box: Close ratio 5 speed. Available in two variations, one with a bolt on final drive and one without.
Exhaust: Larger bore than SPI models, smaller bore than G40. What is the specific bore?
Interior
Clocks: 120 mph speedometer & rev counter as standard, specific to GT rev limit.
Seats & Interior Fabric: More info
Suspension, Brakes & Wheels:
Steel Wheels & Tirms: Steel wheels 13"x5.5J
Exterior
Badges: GT grill and boot lid badging.
Polo G40 Specific Parts:
Engine: Multi-point injection w/ g-lader supercharger. Low compression.
Induction system: Air box, air feed, charger, intercooler, pipe work, throttle body etc. Inlet manifold is shared with NZ.
Rocker Cover & Associated Bolts: Contains boost return passage.
ECU & Loom: G40 specific inc. knock sensor (and?)
Fuel Injectors: Bosch model number?
Spark Plugs: Bosch model number?
Gear Box: ATV with longer ratios and a bolt on final drive
Exhaust: Bigger bore than other models.
Engine Hook: Larger
Interior
Seats & Trim: G40 specific seats, seat fabric & door cards.
Clocks: 160mph speedometer
Boot Floor Carpet: Thicker material
Springs: Different rate & 35mm shorter
Dampers:
Struts: Lower steering arms
Bump Stops & Dust Covers: Shorter to accomodate different spring length
TCA's: Rose jointed track control arms
Steering arms:
Drivers side ARB mount: Different shape to accomodate charger/crank pulley
Brakes: VWII Calipers w/ 239x20mm vented disks
Wheels: 13"x5.5J BBS RA Alloy Wheels
Exterior
Badges: G40 front grill badge & Polo G40 Supercharged rear badges
Bee String Roof Aerial:
Polo GT/G40 Shared Parts:
Distributer: Mechanical advance distributer
Inline Fuel Pump:
Interior
Steering Wheel: Chunky 3-spoke wheel w/silver stripe.
Steering Damper:
Rear Beam Axel: Stiffer with integral ARB
Exterior
Plastic Arch Trim Set
Red Stripe in bumper
Late Spec. Upgrades:
Tinted Rear Lights
Rear Seat Belt Guides
Boot Side Carpets
Factory Optional Extras:
First Aid Kit
Fog Lamps
Adjustable head lamps
Headlamp washers: 7L Washer bottle
Sump gaurd:
Thanks to Tav, Spaniel, Hayesey and anyone else who inputted towards this!
  • Replies 28
  • Views 17k
i would need someone to back me up on this but I'm sure the Gt has:
48mm bore as standard from gt
50mm bore as standard from g40
part no g40 plugs is w5dpo
luke
Edited by ahh claudia
luke
Bosch part number. Other manufacturers (Denso etc.) hae different part numbers, but any motor factors worth their salt will be able to cross reference.
GT seats and interior fabric: Early ones (up to February 1993 at the latest, but maybe someone else can confirm) had black or grey 'Coloured sports check' cloth. Later ones had the nicer 'grey/black triangle cloth' which as the name implies, were small green, red, pink and blue triangles on a dark grey background. I could scan brochure images if that would help.
Also, GT's had specific wheel trims too, with the black centre caps.
inlet manifolds:
nz & py (g40) = 030 129 711 L or 030 129 713 D
GT (3F) = 030 129 711 G or 030 129 713 B
GT dizzy is different, presume same applies to G40.
030 905 205 L = HZ
030 905 205 Q = HZ, ACM (later spec cars)
030 905 205 P = PY, 3F (GT / G40 Respectively)
030 905 205 T = PY, 3F (GT / G40 Respectively Later Spec Cars)
030 905 205 M = 2G
030 905 205 R = 2G (Later Spec Cars)
030 905 205 N (from NZ engine which has the vacuum cylinder on the back (flying sourcer thing))
030 905 205 H = AAU, AAV
030 905 205 AA = AAU, AAV (Later Spec Cars)
Edited by rae
The rear Drums are different too.. See the post here :) Click Me!!!!
Mark
The ECU relay is different on the GT & G40 models. The GT needs a 5 pin rather then a 4 pin which is what the CL uses. Without the 5 pin relay theres no spark or fuel pump prime.
321 919 505A (5 pin)
Ash
Edited by carver
Also GT and G40 have a different Radiator
867121253AB Radiator 430MM / PY,3F
Clutch cable : inboard end of G40 is heavily reinforced compared to standard. Standard cable still fits.
The G40 cylinder head looks the same as the GT but is different G40 has sodium filled exhaust valves for better valve cooling so its better at higher revs
GT runs a 2"external bore exhaust and G40's are 2.25"........ been a long time since i saw a standard version of either!
Edited by Martec
The g40 had two plugs as standard.
Bosch W 5 DTC. 0.7-0.9mm gap
VW part no: 101 000 005 AC
Plug change every 15000km
Bosch W 5 DPO. 0.7-0.9mm gap (longlife plug)
VW part no:101 000 006 AG
Plug Change every 30000km
The ignition timing should be set differently for the two plugs.
for the W 5 DTC timing is 3-7 degrees setting at 5 +/- 1 degree BTDC
And for the W 5 DPO the timing is 4-8 degrees, setting at 6 +/- 1 degree BTDC
hope this is of some help to anybody
Are the spark plugs specificly for a model or year of the g40?
are there any difference in the plugs apart from 1degree of timing?
i'd like to know more :) thanks
Most people just use the w5dpo ones - its what the vw manual syas and what vw supply
ye i've never seen the dtc ones ? anywhere? if i knew there was another option i would have been askin lots of question to the clueless vw guy.
From what it states on elsa i think that the w5dtc plugs are listed for g40's up to 09/90 and the w5dpo's from 01/91.
Apart from that the only difference is that the w5dp0 is a longlife plug so its platinum tipped, not 100% on that though.
I am a a vw technician and I'm always getting my parts manager to search for g40 bits for myself. I will ask him about the w5dtc plugs.
I recently got a set of w5dp0's, the vw part number had been superseeded several times so they were originally listed as another named plug.
I will find out if this is the same for the w5dtc plug. If it is there will be another part number than the one i gave in my previous thread.
i will let you lot know.
checked the Bosch W 5 DTC VW part no: 101 000 005 AC today.
It is specified for g40's only up to 89 model so the mk3 g40's can only use the w5dpo plug.
i forgot to add, the w5dtc plugs are about £4.50 + v.a.t per plug and are available from vw warehouse so will take 1 day to arrive at dealerships.
Mine had the early ones added from new and a dealer told me usually only an option on the GT model.
But there a bastard to keep clean plus the drivers seat support (RH one) and back has frayed due to the loose weave design catching on trouser pocket zips. lol
Despite this they go quite well with the cars color plus at the last show outing a few people commented on how rare the interior color was, but wasn't too sure to believe them or not.
G40s also have larger rear wheel cylinders in the standard drum.
Are the Conrods the same as each other and the other 1.3's ?
Hey guys,
How do the combustion chambers differ on the GT head as opposed to the normal 1.3 head, or are they the same with only the pistons difering?
