1.4 16v engine (code afh)
does anyone know where or who is selling a polo 1.4 16v (engine code : afh) engine??????????? please let me know
  • Replies 10
  • Views 828
Yes mate i have an absolute minter that has been looked after faultlessly it has had all new belts including cambelt and tensioner plugs blue uprated leads oil and filter the works in less than the last 500 miles it has polished rocker and inlet trimsport rocker cap its asolutely spot on £400 Carl 07957 204 365.
what bout 300? 4 is alil much
Right this engine his ready to fit straight in it doesnt need servicing or cambelt or clutch or leads or anything because all of it was replaced 4 months before it was removed from car and the car hasnt done 1000 miles since all of it was done at the same time the inlet manifold and the rocker cover was mirror finished polished so i dont see £400 as being dear however if you just need engine i will let it go without the polished bits and the alternator for £300 but the polished bits really set it off and if you get an engine from elsewhere you are more than likely gonna need to replace cambelt and tensioner and service engine. oh and the leads are fancy blue uprated items aswell which aint cheap either i only want £400 because i now the engine has been so well looked after the previous owner is a very good friend of mine and serviced engine every 7000 miles since he got it when it was 18 months old .also if your a bit worried I'm making all this up you can go onto vr6oc where I'm called kilokilla and you will see I'm very well respected on there because i specialise in vr6 work and have worked on quite a few of there cars.Carl.
Edited by The Volkswagenator
bump
come on boys anyone else seling an engine for 16v afh polo 1.4?
bump
bump
bump
bump
