Showing content with the highest reputation on 10/03/23 in all areas
  1. Pete1
    Oil temperature sensor is combined with oil level sensor in the sump, part number will be visible from below. Coolant temperature sensor is the main sensor for engine temperature, not sure on physical position, usually a coolant flange on the engine head somewhere. (Two-pin connector with white/yellow and brown/yellow wires at sensor) There are two in the air intake tract, both combined with pressure sensors, again I'm not sure of physical positions. No fuel temp sensor as far as I know. Part numbers will be much easier to find with VIN, please supply here or in a private message.
This leaderboard is set to London/GMT+01:00
