Showing content with the highest reputation on 10/16/23 in all areas
  1. dvderlm
    Cold oil not circulating, yeah it probably left some crud that got inside a tappet. If not changed for many miles the oil filter might even have opened its bypass valve so not filtering. Don't drive without air filter.. but fine for investigation in a none dusty or gritty place. If you are going to leave it for any length time cover the inlet. I have used clean cloth, plastic bag and rubber glove over the years.
  2. mk2tastic
    It sounds like a possible rattle from a hydraulic tappet. If the engine hasn’t been run for 4 years the tappets, or at least some of them, will likely of lost oil. If your oil light goes out on starting the engine and you’ve done a change with the recommended oil, it’s sometimes an idea to rev the engine for a few minutes, then idle again to see if it quietens them down. You can repeat this process a few times. Just letting it idle may not quieten them down. I’ve just bought a new set of INA tappets for my MK2 polo and the recommendation is run the engine for 4 minutes at 2 to 3K revs,then 30 seconds rest and seeing if they quieten down, if not repeating the process for a further 4 minutes. If that doesn’t work do it for 6 then 7 then 8 then 9 minutes, with a 30 second rests in between, in total 5 attempts to stop the rattle. If that doesn’t sort it then you may have a faulty hydraulic tappet/camshaft or an oil pressure issue. As I say this is the recommended procedure for NEW tappets, but it might do the trick, especially as your engine has been stood for so long. I emphasise you must ensure your oil warning light goes out before trying this.
  3. dvderlm
    Thanks. Yes sounds very like hydraulic rocker(s). You could take the engine cover off and use a "listening stick" to try to narrow down which cylinder(s) have the problem. Like a poor man's stethoscope, hold a long screwdriver against the cylinder head working left to right. Might be able to clean insides of the lifters with engine flushing additive. Or might need a garage to change worn / dirty lifters. Was oil real hot when you changed it?
  4. dvderlm
    I only hear exhaust for that. Can you record from engine bay? Probably the hydraulic tappets slow at pressurising, so the cam lobes slap the valve ends, rather than stroking them.
This leaderboard is set to London/GMT+01:00
