Showing content with the highest reputation on 04/22/25 in all areas
  1. dvderlm
    if you have changed to a known good sensor, then I'd suspect its connector or wires. And if they are in a good state and with continuity to the ECU (need a wiring diagram, sorry for the right pin, I can only suggest earth connections. Battery negative to engine. Connect a fat jump cable from battery negative to the block, and see if it still happens. Make sure the clip can't fall off and foul something.
