Showing content with the highest reputation on 10/21/25 in all areas
  1. strobe
    2 points
    Removing Polo's wiring Removing polo's ECU essencials and ecu peripherals. Also removing fused protected power and a set of +5VDC and GNDs that power engine sensors. ECU peripherals ECU essencials This was paired with my speeduino, so I had to remove both. Fused protected This cables go to the inside of the car some are fused others not. VSS (vehicle speed sensor) is here. Injectors +12VDC fused cable is here. A spare +12VDC is also here and ignition protection, also +12VDC. A good set of +5VDC and GNDs are here also, all going to be inhibited.
